Hi Jeff
Strictly speaking, if the base metal is not listed in the AWS D1.1 tables, then it you cannot assign it to a "Group". Having said that, if you are building this for a non-USA client, then they may be happy for you to classify the base material, as it is technically the same as a Group II material. I would address this to the client with a technical query, suggesting to classify it as "Group II".
I would also suggest that this type of question should rather be posted on the forum dealing with AWS codes. The AWS experts hang out there!
Regards
Niekie
• Ladies and Gentlemen,
Did quick run on and
ASTM A283 GRADE D| A283 Gr.D STEEL PLATE - …
www.s355nlsteel.com/china/A283-GRADE-D-A283-Gr.D.html
ASTM A283 GRADE D| A283 Gr.D STEEL PLATE ... Equivalent steel grade of ... S690Q,S690QL,S890Q,S690QL1,SM570,S355J2G3,S355J2+N and so on high quality steel ...
. I hope this is helpful.
Sincerely
Len Andersen weld@spemail.org
914-536-7101 / 212-839-6599 8-4 New York Time , 4042 FAX , Co-worker 6381 / 914-237-7689 (H)
POB 1529 / NYC 10116-1529 ( $1160 per year Caller Box GPO NYC / Most Secure Service At Largest Post Office )
