Hello everybody!
I`m working on an industrial cold rolled steel sheet coating plant, where we add zinc to the surface of a steel sheet provided by a coil. (galvanizing line)
As the process is a continuous line, we have a loop car, and as soon as a coil ends, we weld the beggining of another coil on it.
Lately, the welded section between the end of a coil and the beggining of another is not resisting, and ruptures (spliting) are occurring in different parts of the process, causing the whole line to stop, wich brings us a lot of problems in order to fix and align everything and start it up again.
We are using an automatic Resistance Welding machine. It has 2 roller electrodes (discs), wich rolls on each side of the two steel sheets in direct contact, applying force and current (Ampers).
For what I already searched on the internet, it is refered as "Seam Welding".
Does anybody here have experience on this kind of process in resistance weld?
The only useful information I got so far, is from a Ruuki`s Manual:
http://www.ruukki.com/~/media/Files/Steel-products/Cold-rolled-metal-colour-coated-instructions/Ruukki-Resistance-welding-manual.pdfVery interesting stuff!
So, I`ll be spending the next few days analizing the machine parameters, the kind of sheets it is welding, and other things related to the process, such as failures and their aspects.
I don`t have much experience in this field, so, any help or tip about it would be of great importance.
Sorry for my english and thanks for your attention.
