The base metal, that is the carbon steel part is exposed by gouging out the chromium carbide layers by means of grinding or arc gouging. Then a suitable vee-groove is made on the carbon steel to weld it with E7018 or any suitable semi automatic filler. Once the welding is done, the cap is flushed with the base metal surface. The removed chromium carbide is filled by suitable hardfacing electrodes for example CHROMOCARB N 6006 ( from CASTOLIN ) which have a similar carbide content.
You will experience cracks, called stress relief checks when you weld the hard facing electrodes but the cracks are superficial and not harmful if the service condition is not corrosive. Most of the wear plates are welded by this process
