The question is what is the tightest turn it can bend and does it have the right mandrels for your tubing. You can bend it in pieces and weld the finished part at the top but that is extra steps and accuracy is paramount. If the machine is hooked up take a section of tubing and check it out, if it does what you need great if not it has cost you a piece of tubing, cheap compared to a boat anchor you can't use.
Good luck,
pjseaman
