badge1988, I don't have access to 25239-3 at the present but as a quicky, if you look under section 2, it should give you a list of 'Normative' standards, if it mentions EN287 or less likely 9606 then those are the standards for your welding operators to qualify.If this is so, welding position is an essential.
