But the A-number and clasification are the same. I don't see, where is the applicability, which you are mentioning. by other hand, the requalification should consist in make mechanical tests + cvn test in weld metal (certified by consumable manufacturer) and CVN in HAZ, that should be basically the same because the wps parameters are the same. I am not saying that i am right, its just a thought. I feel that a requalification should be not necesary, but in 30 days i will have an exam, if they ask me, I will respond, requalification is necesary.
Thank you.
