Up Topic Welding Industry / Technical Discussions / WPS for Weldox 700
- - By mohsen roshani (*) Date 07-15-2014 15:47
Hello my friends
i need to write a WPS for Weldox 700
the joint type is fillet
something i must know:
1-welding using MIG or MAG or TIG for root pass?
2-for welding a 9mm plate is it necessary to weld use SMAW for filling pas?
3-what PWHT should be apply?
4-i have plates of 9mm and 25mm thickness to weld on 38mm plate, can i use only one WPS? or 2 WPSes should be employed?
Parent - - By Joey (***) Date 07-17-2014 01:04
cont....
5-am I qualified to write?
6-what code to follow?
7-what welding processes are available at worksite and preferred by my management to use?
8-do I have a skilled welder to do the procedure qualification?
9-do I have a budget constraint for making multiple WPS?
10-do I try to google by getting more info?
what else i must know??? :eek::lol:
Parent - By mohsen roshani (*) Date 07-18-2014 06:38
yes and it's for fabricate Flynns Buckets
Parent - By pipewelder_1999 (****) Date 07-17-2014 12:49
http://www.ssab.com/Brands/Weldox/Products/Weldox-700/ would be a good place to start for actual welding requirements.
Then consult the specific code used for fabrication to see what variables ranges need to be qualified.
Gerald Austin
