Do you mean this test? It certainly looks like the one you're describing except for the pink color which in this one it's more of a pink rose color than a bright pink...
http://www.elmerwallace.co.uk/23.105-Passivity-Test-Kit/99.htmThis one is the Copper sulfate test which is an alternative to the cyanide test mentioned below by Sperko Engineering:
http://www.elmerwallace.co.uk/Fast,-simple-Stainless-Steel-test-kits/Copper-Sulphate-Test/C10-117-1-0.htmThis one is really High Tech gizmo
http://www.elmerwallace.co.uk/Passi-Test-Plus---Passivation-tester-%28click-for-video%29/175.htmOr one of these Doo - Hickies:
http://www.vecom.nl/english/productsheets/marine/0809_oxilyser3.pdfThis the Ferroxyl Test that's
very toxic and DANGEROUS and potentially Life Threatening:Ferroxyl Solution for Finding Free Iron on Stainless Steel
Distilled Water 1 liter
Nitric Acid 30 milliliters
Potassium Ferrocyanide 30 grams<<<<
EXTREME CAUTION!!! Note this method of testing is very toxic, and potentially life threatening...
DO NOT USE with any stainless steel associated for
any use with foods because of the cyanide.http://www.sperkoengineering.com/html/Rust.pdf Another good article, or two, or three, or more:
http://innomet.nl/docs/Flashrust.pdfhttp://www.euro-inox.org/pdf/map/Passivating_Pickling_EN.pdfhttp://www.ssina.com/download_a_file/cleaning.pdfhttp://www.cartech.com/techarticles.aspx?id=1566http://www.aws.org/w/a/wj/2002/05/feature/I helped to install quite a few of these amongst other brands of Cooling Towers, Closed Circuit Coolers, and Evaporative Condensers all over the Metro - New York City, Long Island, and Westchester County... Too many "lolly" columns and structural frame work to remember how many we erected to mount the units on... This is an informative bulletin:
http://www.evapco.eu/sites/evapco.eu/files/white_papers/40-Cleaning-Stainless-Steel.pdfGood info here:
http://www.pennstainless.com/blog/tech-resources/general-product-information/corrosion-prevention/http://www.pennstainless.com/blog/tech-resources/general-product-information/maintenance-and-repair/http://www.pennstainless.com/blog/tech-resources/general-product-information/cleaning-stainless-steel-3/http://www.pennstainless.com/blog/tech-resources/general-product-information/ams-cross-reference-chart/I just thought of adding this also:
http://www.derustit.com/pdfs/CorrosionReportFlyer_v3.pdfThis stuff is fantastic but not inexpensive!
http://www.nanovations.com.au/metal.htmThere's more but, I'm going back to sleep... Best of luck.
