Hello wrenchtech, I used to work for a heavy equipment manufacturer quite some time back and that's what they used on the majority of the pivotal areas on a lot of the equipment that we built. 4140 TGP (turned, ground, and polished) was what they often used. This included clam-shell buckets, log grapples, and a host of other stuff. There are likely better choices out there now, yet this is a choice that has been used in the past with reasonable success I would say. Best regards, Allan
First, yes, 4140 is a good choice.
I second the cautions added by Allan and Al. Most heavy equipment will have one surface designed to carry load and support the pin while the other is designed to allow the rotation movement and wear at a reasonable rate while allowing for easy rebuild and/or replacement of parts (bushings, arms, brass inlay, etc) Homeowner equipment is not usually as well designed and wears out at all points of contact.
There are even times where the pin is the item designed to wear out and be replaced. Operators must be aware of slop developing in joints either way and know when to get it to the mechanic. Otherwise more time, parts, and expense are required to get back into working condition.
