Okay, I see a couple of mistakes in my comment as I was trying to make a comparison point and did not pay close enough attention to my details. While 3/8" root openings are common in production, they are not for performance quals which is the current context.
I also used 90° groove angle when it should have been 45°, 22.5° on each bevel. Wider angles are permissible in production but not performance. Single bevels, which I am dealing with a lot right now, can be 45° + 10° = 55°, but that does not equal a 90° for a V-groove for a performance qualification which is 45° period per Clause 4.
My point being though how the steels come together and absorb the 'heat' of the arc and weld pool so that it is more difficult to get good fusion to the root in a T-joint with fillet welds than it is in a groove joint with backing and welding with the applicable groove weld.
I see welders using processes with the electrode 'pointed' in the wrong direction and/or just the way they are allowing the weld pool to flow thus allowing the weld pool to be between the arc and the root so that good penetration is not achieved. This will also, depending upon process and other factors, allow slag entrapment as well as lack of fusion at the root which makes penetration even more difficult.
I agree with Al's analysis of the variation in process power sources as well. When I used the old Lincoln 'jet engine' 440 3 phase welders and the old portables with the large generators, if you couldn't lay a good weld regardless of fillet or groove you really had a problem. But, with the power sources today, it takes many welders some hard work, lots of practice, and several failures before they get a technique they are consistently successful with.
Would not have been your foot in your mouth, my wife is still working at getting the come-a-long positioned to extract my two feet from mine.
Brent
