You have to sell your customer on the idea that a WPS qualified by others meets their needs. I work with one railroad manufacture who's customers will not accept SWPS qualified and meets AWS B2.1.
One of the problems I find with AWS B2.1 is that it is based on the requirements of ASME Section IX. Section IX is the one welding standard that allows the manufacturer to qualify the WPS without recording any of the information the welder needs to produce a good weld. One does not need to record arc voltage, welding current, wire feed speed (for semi-automatic welding processes), travel speed etc. on the ASME PQR. That being the case, under Section IX and B2.1, one can simply use the SWAG method to determine the useful range for arc voltage, welding current, travel speed, etc. It makes me wonder what the SWPSs use as a basis of determining the permissible ranges? Does the B2 committee use the SWAG method or are the ranges based on actual test results? We'll never know because AWS doesn't give the license holder access to the supporting PQRs.
Be aware that the SWPS is not intended for use where notch toughness or PWHT is required.
I would be a little hesitant to accept AWS' marketing department as being any different from any other sales person you've dealt with. After all, they are trying to sell you something. Horse traders, used car salesman, AWS marketing department, they all belong on a covered wagon plying their pots, pans, and snake oil to the unsuspecting.
Thank you gentlemen for the replies.
We're still on the fence about B2.1. On one hand, it would make sense to qualify welders with less tests, but on the other hand, it may not be as versatile as I previously thought.
Al, you make a good point about AWS' marketing department. Also, I really don't like that the SWPSs do not come with the supporting PQRs that "prove" the procedure.
If anyone has experience using B2.1 or uses/has used this standard to qualify their welders, I'd love to hear what you think about it.
Again, thank you Lawrence and Al for your replies. You two seem to be the lifeblood of this forum.
I had a couple of clients try to use them (SWPSs) as written. The welders could not pass the tests using the information provided by the WPSs regarding the groove preparation, purge gas, etc. I ended up modifying the SWPSs to provide the welders with the information they needed to set up the machines and prepare the grooves. So much for the ranges permitted by the SWPSs. All we proved was the welder's could not get acceptable results following the SWPSs as written.
