dschlotz:
No one has replied to any of your posts, so I'll help out a little.
1.) The E70T-1/E71T-1 electrode specified in in the SWPS number you posted only has a notch toughness requirement of 20 ft-lbs @ 0 degrees F in accordance with the electrode specification AWS A5.20-95 (Table 1). Most seismic and structural applications require a 20 ft-lbs @ -20 degrees F. The above WPS would be acceptable if the supplemental designators J or MJ followed the E71T-1.
The E70T-1/E71T-1 electrodes have a notch toughness requirement and can be used for structural applications, they just don't meet the current industry standard were a more stringent toughness value is required (e.g.: Seismic Zone 4 found in the IBC/UBC and per FEMA 353). It depends on your locale.
An E71T-8 (SWPS B2.1-1-018-94) would have satisfied the above 20 ft-lbs @ -20 degrees requirement.
I'm not trying to rub your nose in it but you should have researched before purchasing. The SWPS list in the 2004 catalog specifies the electrode classifications (e.g.: E7XT-X). The AWS (Global Eng.) will sell you a WPS for sure, but you must tell them the specific application for the toughness requirement.
2.) Your other option is to comply with the D1.1:2004, Section 4, Part A, 4.1.1.1 and simply qualify the procedure yourself. Here in CA, the engineering community does not recognize these "canned" procedures and require each contractor to qualify the WPS(s) for the project even though the SWPS's are acceptable per 4.1.1.2 of the same code section.
3.) As far as numbering or identifying of WPS, PQR or WPQR's, any convenient system may be used.
Good Luck.
