Up Topic Welding Industry / Inspection & Qualification / D1.5 Re qualification of welder
- By billk63 (*) Date 09-18-2015 21:02 Edited 09-18-2015 21:08
IN D1.5 when the welder s 6 month continuity has expired and re qualification is required ,does the test plate require RT and bend test  ,or only bend test is required ,the WPS has not changed
this is Fracture Critical
