Up Topic Chit-Chat & Non-Welding Discussion / Off-Topic Bar and Grill / F135
- - By Sourdough (****) Date 10-25-2015 14:09
My big 40 finally quit me. Red seal f163.
I've got a freshly rebuilt f135 that was going to go into an old forklift I have...
Question is: will the 135 ci red seal work in the big 40?
Parent - - By Trackergd (**) Date 11-24-2015 13:47
Did some quick checking and found that the F163 puts out about 20 HP at 1500 rpm.  162 Cu In with a 7.4:1 compression ratio.  The 135 is 124 Cu In with a 6.07:1 compression ratio.  Less horsepower, I'm guessing about 10.  The Continental F series used a common block  If the forklift is a Clark, they had oddball blocks and they are set up for a hydraulic pump.  The F163 probably has an updraft carb and governor.  "If" the blocks measure up the same at the connection and you can swap over the governor, it might work but again, less horsepower.  There is a website with additional information,  Google Bills Welder Repair.  Another resource might be the multi cylinder stationary engine forum in SmokStak.  Hope all this helps.
Parent - By Sourdough (****) Date 12-09-2015 03:45
Thanks Tracker....good info.
- - By Dualie (***) Date 12-01-2015 05:33
Hey sourdough i got a LIKE NEW big 40 here in CA, less than 1000 hours since new in 72.
Parent - - By Sourdough (****) Date 12-09-2015 03:44
What are you asking.....
Parent - - By Trackergd (**) Date 12-09-2015 20:49
I think Dualie is trying to sell you another Big 40..
Parent - - By Dualie (***) Date 12-11-2015 07:07
^ nailed it.   Make you a hell of a deal sourdough.
Parent - - By welderbrent (*****) Date 12-11-2015 22:55
I believe Sourdough was asking 'HOW MUCH DO YOU WANT FOR IT?' when he said "What are you asking..."
BB
Parent - - By Dualie (***) Date 12-12-2015 06:32
Good catch welderbrent.:confused:   Its been a long week i will PM him
Parent - - By welderbrent (*****) Date 12-12-2015 17:18
For the record, I don't pretend to know for sure and I sure don't speak for Clay.  It just appears that way to me.  Also, using caps and bold type was to draw attention to the question, not to be taken as yelling or any other emphasis.
Brent
Parent - By Dualie (***) Date 12-15-2015 04:45
No harm brent.   I have come to the realazation with a pending move of facility's that i have far to many redundant things.  Time to start pairing down the stock.
