Up Topic Welding Industry / General Welding Discussion / WPS / PQR
- - By CARLO Date 11-13-2016 18:45
Hi
WPS and PQR -Being the qualification to the WPS the PQR,is it possible for the PQR to be dated in 2012 where the WPS is dated 2016 ?
Parent - By pipewelder_1999 (****) Date 11-13-2016 20:27
In most codes, there is no expiration on a PQR. A company could qualify a procedure and record the data on the PQR and at a later date, prepare a new WPS within the qualified ranges of the applicable code.
In many cases, a single PQR may support various WPS's as is the case with ASME Sec IX.
Parent - - By welderbrent (*****) Date 11-13-2016 20:27
As long as the code the PQR was performed to is still applicable as to all the essential variables, testing, etc.
The WPS can be written later, all other things being equal and correct.
Parent - By 803056 (*****) Date 11-14-2016 03:33
I concur.
Parent - By pipewelder_1999 (****) Date 11-15-2016 00:10
QG-108 QUALIFICATIONS MADE TO PREVIOUS EDITIONS
Joining procedures, procedure qualifications, and performance qualifications that were made in accordance with Editions and Addenda of this Section as far back as the 1962 Edition may be used in any construction for which the current Edition has been specified. Joining procedures, procedure qualifications, and performance qualifications that were made in accordance with Editions and Addenda of this Section prior to the 1962 Edition may be used in any construction for which the current Edition has been specified provided the
requirements of the 1962 Edition or any later edition have been met.
Procedure specifications, PQRs, and performance qualification records meeting the above requirements do not require amendment to include any variables required by later Editions and Addenda, except as specified in QW-420. Qualification of new procedure specifications for joining processes, and performance qualifications for persons applying them, shall be in accordance with the current Edition of Section IX
