"Now, I would reverse the process and weld a backing weld, two or three passes, on the inside first and follow up with backgouging by grinding or air arc on the outside and finish welding from there."-Brent
Yes...make it easier on your welder by performing the back gouging on the outside. All of that air and hot slag flying around up inside with your welder makes for a miserable job.
