Hi Lawrence,
Is this a Spray transfer mode?
Semi-Automatic GMAW 1.2mm wire diameter,
Ampere=230~250,
V=31~32,
Typical welding Speed=8~12mm/sec,
Heat Input Range=5~8KJ/cm
how about this?
Automatic GMAW 4.0mm wire diameter,
Ampere=900~1000,
Voltage=20~21,
Typical welding speed=50~60mm/sec
Heat Input Range=2~4KJ/cm
Welder should be qualified as per Table QW-461.9 - Pipe-Groove @ 2G test position ?
Thanks,
Are Aye
