bearing surface of input shaft has been grooved by excessive use and little maintenance. The shaft is splined on one end and has a yoke on the other. The bearing surface is about two inches long. Question??? Does this type of steel used in this particular application need to be annealed before welding. If so after welding does it need to be quenched in an oil bath after being brought up to temperature.
Firstpass
