It appears you are qualifying the WPS in accordance with ASME Section IX. If that is indeed the case, ASME allows the joint to be welded with one or more WPSs and each WPS can be for one welding process or multiple welding processes provided there are supporting PQRs.
Please verify the applicable construction code has been reviewed to check whether CVN is required and whether PWHT is required.
