Up Topic Welding Industry / ASME Codes / weld branch tolerances
- - By eslam soliman Date 01-15-2018 12:14
hey dudes i would like to ask about weld a pipe branch in the field without fittings to the main pipe directly and it's function drain, the work area is inside the power plant, the reference code is asme b31.1 ed 2012. is it allowed in this code to weld it in the field.
Parent - By Loren Date 08-17-2018 07:51
Good info thank you
