Up Topic Welding Industry / Inspection & Qualification / steel structure
- - By H.K.R (*) Date 03-12-2019 10:44
dear all
which code explain the tolerance of steel structure
i have tanks roof structure i need to know the tolerance
Parent - - By TimGary (****) Date 03-12-2019 12:24
That's a broad question with little detail to provide an answer, but here's some info to help get you started.
Raw components may be purchased to specifications, such as provided by ASTM.
For example, a specific ASTM grade of carbon steel shape certification is:
ASTM A992/A992M-11(2015) Standard Specification for Structural Steel Shapes
This is only one example of many such specs...
However, the only place to find the real answer to your question, whether for material purchase or fabrication specifications, is in the contract documents that govern the tank construction.
Tim
Parent - By H.K.R (*) Date 03-14-2019 04:33
thanks for reply
you know during construction we must to keep quality
so if we have a column we must keep a good vertical also for horizontal
