If you are looking for a methodology or rational basis of qualifying the process, consider AWS D17.2. The standard is for aerospace, but it does provide a rational basis of qualifying the process. You can determine whether the appropriate weld category is, i.e., Class A, B, or C for your particular application and then you can qualify the schedule (process) based on how you categorize the welds.
Good luck - Al
