Not knowing which code you’re using, if any, in AWS D1.1, the Structural Welding Code for Steel, Table 3.3 is a list of prequalified base metal material grades, material thickness, and welding process, which determine the amount of MINIMUM preheat based on the thickness of the thicker part at the point of welding. This table requires the process and thickness you listed to be preheated to a minimum 50 degrees.
Edit: not sure where you are, but if the temperature of the steel (assumed base metal) is already at least 50 degrees, preheat may not be a concern.
