Additional Information.
yes it's related to Overlay welding (Cladding). I have a qualification for a welding operator with AISI4130 base material + Inconel 625 filler wire.
Whether this welding operator can do overlay welding (Cladding) for different Base material with different filler wire without qualifying him again.
Since we have different welding procedure as below, we don't think we need to qualify welding operator for each procedure as below according to ASME SEC IX clause QW-361.2
Sl.No. 1, Base material AISI4130 + Filler wire Inconel 625
Sl.No. 2, Base material A106 + Filler wire Inconel 625
Sl.No. 3, Base material A106 + Filler wire SS316L
Sl.No. 4, Base material SA234 WP22 Cl 3+ Filler wire SS 347
Sl.No. 5, Base material API 5L X65 PSL2 + Filler wire SS 316L
Sl.No. 6, Base material F22 + Filler wire Inconel 625
Sl.No. 7, Base material Alloy 625 + Filler wire Inconel 625
Advice me.
Jegan t
you are correct with the exception of QW-301.1 If you are concerned that these different materials do constitute an essential variable based on knowledge and experience then you can test them. (Welders) Remember, you are trying to determine the ability of welder or welding operators to make sound welds.
