Up Topic Welding Industry / Technical Discussions / GMAW Gas Selections
- - By jer (**) Date 01-28-2005 05:09
Is there a gas blend that can be used for both metal core wire and reg. hard wire.
Parent - By backpurge (*) Date 01-28-2005 12:09
Depends to a certain extent what is specified by the wire manufacturer but in the UK the most common gas mix for welding carbon steel with cored wire is 80% argon/20% carbon dioxide and this is fine for solid wire on base material above 5mm thick or so.
Some cored wires run fine on a 100% CO2 mixture and you can get acceptable results with solid wire on carbon steel also but not as good as with a "mixed gas"
The only problems you would get would be if you were welding stainless steel, you would still be able to use 80/20 for the cored wired but would need to use a different gas (98/2) for solid wire
Hope this is of use
Cheers - Bob
Parent - By Lawrence (*****) Date 01-28-2005 14:00
Jer,
Always check the manufactures data.
Here are a few examples of metal core wire that require shielding gas common to hard wire.
http://www.hobartbrothers.com/pdf/MetalCor6.pdf
http://www.hobartbrothers.com/pdf/MetalCorEn_Vision.pdf
http://www.hobartbrothers.com/pdf/Metalloy70.pdf
Parent - By Bill Mc (**) Date 02-10-2005 13:36
FYI-
There is a good article in the January 2005 issue of "Practical Welding today" magazine titled:
"Simplifying Shielding Gas Selection- How different gases and gas blends affect your welding application".
