Up Topic Welding Industry / Technical Discussions / WPS Qualification w/o Radiographic Test
- - By peterbil (*) Date 03-08-2005 06:46
I am trying to determine if it's possible to qualify my WPS w/out radiographic test, is this a requirement in every test you made to qualify a WPS? Is/are there statement/s in ASME IX indicating the need for radiographic testing everytime you qualify a WPS? I'll appreciate your reply to this post thanks.
Parent - - By ajoy (**) Date 03-08-2005 07:26
Radiographic Tests are not required as per ASME IX. The requirement to carry out RT is based on the project specifications. However, carrying out RT is advantageous to the contractor if he wants to use a welding procedure in more than one project, some of them having requirements for radiographic tests in the PQR.
Parent - By peterbil (*) Date 03-09-2005 00:49
Hi Ajoy,
Thank you for your reply I was able to read ASME IX specially QW 140 and QW 142, QW 304.
