Safari:
Back in the” old days”, before the widespread use of check valves and flashback arrestors, beginners were always taught to balance gases. This is a procedure I still use today, not only because of safety, but because it is a good way to check on the current condition of your equipment, and guarantees the correct setting with any tip size or regulator gauge peculiarity. With a little practice, it only takes a minute, and accurately gives you the proper setting with any make of equipment, with the max. and min. of the heat range of any tip. The instructions I usually give an OAW beginner are below.
With both bottles on, and regulator adjusting screws turned out (“off” position), turn the acetylene torch valve wide-open (3 half turns is usually enough). Then, turn your acetylene regulator adjusting screw in until gas starts to flow and light the torch. Continue to turn the adjusting screw in until the flame just blows away from the tip, then back off the screw until the flame just returns to the tip. Your acetylene pressure is now set for that tip.
Then , open the oxygen torch valve wide-open (3 half turns) and slowly begin to turn your oxygen regulator adjusting screw in until you you have a blue feather extending from a blue cone at the tip. Continue to add oxygen until the feather just disappears into the inner cone, giving you a neutral flame. You now have the torch set for maximum heat for that tip. (Wiggle both torch valves at this point to make sure you have them wide-open: if you do, the flame will not change)
Finally, turn your oxygen torch valve off. Then, close your acetylene torch valve until the yellow flame starts to produce smoke, and immediately open it just so it is not smoking. Slowly open your oxygen torch valve until you again have a neutral flame , and you now have the minimum flame you can use on that tip without backfires.
This seems like a lot of trouble, but only takes 1-2 minute with practice and only needs to be done once each session, unless tips or regulator settings are changed. Also, note that at no point are you depending on or even looking at regulator gauges, which can be very unreliable when abused. This method will work with all standard OA equipment for welding.
You will use less gas, and have faster results, if you switch to 16ga. or 1/8” material for practice.
Good Luck!
Ilearned to use the meathod you described when useing guageless regulators and now thats the only meathod I use.It really works well and like you mentioned,its fool proof.
By Safari
Date 03-30-2005 00:50
Northweldor,--------Thanks so much!!!, I will practice this proceedure and try to get it down. Your right, I have been going thru the gases real quickly. Maybe this method will work. Again, thank you for this information.
