Up Topic Welding Industry / General Welding Discussion / which tweco line will work with lincoln
- - By toby6060 Date 07-29-2005 19:36
will any of the tweco wire liners work with the lincoln 175 plus... the 100l gun, i need the .035 teflon liner and one for the .045 wire
Parent - - By n5uzt (**) Date 07-30-2005 15:14
yes the tweco liners will fit the lincoln
check with your local welding supply co.
tell them the gun model you have and wire size
Parent - By thedoctor (*) Date 07-31-2005 15:34
The part numbers for Tweco are:
45-40-15 Numeric 1400-1143
35TF-40-10 Numeric 1400-1031
Please note that the aluminum liner is not available for guns longer than ten feet.
