Up Topic Welding Industry / Technical Discussions / fulll pen welds
- - By CBISTEEL Date 01-15-2006 17:44
I am would like to uderstand why the engineer is having me remove back up bars on bottom flange of weld.The welds that i am talking about are full pen. moment welds attaching w?*??into face of col.the average beam size W18*40, col.s are W12*136.full pen top and bottom flange
Parent - - By jwright650 (*****) Date 01-16-2006 00:37
Sounds like a seismic moment connection. FEMA 350 has typical details of these type connections. this is not uncommon to remove the backing bar and add an additional fillet weld.
John Wright
Parent - - By vonash (**) Date 01-16-2006 21:26
I agree,
The backing bars may create false indications which may be constued as LOF, etc.. FEMA and newer procedures require the removal of the backing ; and some engineers require and additional reinforceing fillet weld at the point of stress.
It seems the botton flange of the beam receives the most stress during a sesmic event.
Parent - By HgTX (***) Date 02-08-2006 22:52
The unfused portion of the backing bar where it meets the fused portion makes for a notch that can start a crack at the weld root during a seismic event or in a fatigue application.
Hg
