I am in need of schematics for an olde SA 200. It is the popular gasoline powered (continental 4 cylinder), with magneto. I need enough diagrams to cover the exiter, the main generator, charging circuit, Hi/Lo idle circuit, and so on and so forth. In other words, all of them. Specifically, I have the model which features what I believe to be the 3rd generation idle control-- eg. the idling takes place when a circuit board mounted inside of the control panel decides that no welding or electric current have been required for a predetermined time frame and subsequently sends a signal to the idler solenoid to lower it to idle. I believe it to be the first of the non- vacuum actuated idle controls. However, any and all technical information regarding any of the entire series of SA 200's would be gratefully appreciated. Thanks,
Mike
