Up Topic Welding Industry / Technical Discussions / API 1104
- - By Richard V. Roch (**) Date 03-30-2006 20:23
Talking about thickness range. In API 1104 for procedure qualification, para. 6.2.2, e 3, it states "Nominal pipe wall thickness greater than 0.750 in. Does this mean that if I qualify a procedure using .875" thick coupon my thickness range would be from .750" to unlimited?
Help and thanks in advance.
Parent - - By chall (***) Date 03-30-2006 20:35
The referenced paragraph is for performance testing of welders, not procedure qualification.
Paragraph 5.4.2.5 (applicable to procedure qualification) says exactly the same thing, but no thickness ranges are given. I believe it was intended to have the same thickness range listed in 6.2.2.e.3 (see 5.3.2.3).
This was a long way of saying that I believe your interpretation is correct.
BTW, I am looking at the 19th ed, Sept. 1999.
Charles
Parent - - By Richard V. Roch (**) Date 03-30-2006 21:06
You are quite right. Para. 5.4.2.4 states that a change from one wall thickness group to another constitutes an essential variable. Para. 5.3.2.3 says examples of suggested groupings in 6.2.2 items d. and e. I guess the implication here is that one wall thickness group in 6.2.2 is from 0.188-0.750 and thickness greater than 0.750 would be another group.
thanks
Parent - By chall (***) Date 03-30-2006 21:17
Yes, I agree.
Charles
