Up Topic Welding Industry / Technical Discussions / welder Qualification for stub-on/stub-in
- - By Ajirajnatarajan Date 04-19-2006 14:04
For welding stub-in nozzle on a vessel,what is the diameter for which the welder should be qualified?Is it the vessel dia. or the nozzle dia.?
Parent - - By Shane Feder (****) Date 04-19-2006 20:46
Nozzle diameter,
Shane
Parent - - By MBlaha (***) Date 04-20-2006 03:45
Would this be a full penetration weld? Do you have to backgouge and reweld the back side?? If so, would it not be the diameter of the vessel??
Just asking
Mike
Parent - By Shane Feder (****) Date 04-20-2006 13:50
Mike,
The diameter of the vessel is totally irrelevant.
I presume we are talking ASME IX.
For a 2'' nozzle they would do a welder qual on any diameter less than 2 7/8'and that qualifies for 1'' and greater to unlimited diameter.
Test coupon on 2 7/8'and over qualifies for that diameter and greater.
Hope this helps,
Shane
