Hi Dasimonds,
I can't speak for armywelder because there are many different ideas as to what makes a weldable, open root joint with the alloys. We used a tight 3/32" root opening with 3/32" lands.
Some welders run a keyhole, some bury the arc. It's whatever works for each welder. The best technique I found to qualify and consistently meet the quality standards in production work was to run extermely fast (compared to welding CS roots) with a tight arc, maintain a small but uniform keyhole, and "tick" each side of the joint with the electrode. My old instructor, who has gone to the Great Welding Shop Beyond, refered to my technique as "Seldom's sprinkle-pass" because that's what it reminded him of when he watched me.
Hope I haven't over-stepped my bounds with this discussion but I figured it's Shop Talk.
Hi Seldom,
Thanks for the tip. Your description of the technique you used sounds similar to the way in which I manipulate stainless SMAW. It is a difficult process to become proficient at. We use it for testing purposes to fill and cap a 2" SCH 160 coupon, but only after it has been rooted and filled half way out with GTAW. I can't say I've ever seen the corporation I'm employed by use Stainless SMAW on pipe in a production environment, even for the filler passes. I think it is mostly related to the fact that some believe that a GTAW joint is somehow "better" than a SMAW weld. I personally believe if the process is correctly applied, according to procedure, there isn't any real difference in the final weldment, other than appearance. I'd like to run one of armywelder's coupons. just because I've never done it before. Again, thanks!
Dale Simonds
