Up Topic Welding Industry / Technical Discussions / Welding of Inconel 625 to Hastelloy C-27
- - By Hojo (*) Date 09-25-2001 14:43
We have a project coming up requiring the welding of C-276 flanges to and Inconel 625 rolling. The flanges will be a slip-on type and will be approximately 2.5" thick. The Inconel body will be 3/8" in thickness.
Any idea of the correct filler metal to use. I believe it would be Inconel 625 but am not sure.
Parent - By MBSims (****) Date 09-26-2001 04:10
Alloy 625 weld electrode or filler (ENiCrMo-3 or ERNiCrMo-3) is acceptable. Alloy C-22 (ENiCrMo-10 or ERNiCrMo-10) or C-276 (ENiCrMo-4 or ERNiCrMo-4) may also be used.
Ref.: Guidelines for the Welded Fabrication of Nickel Alloys for Corrosion-Resistant Service, Series No. 11012, 1994. Nickel Development Institute.
You can find a lot of very good, FREE info on welding of nickel-base alloys at: www.nidi.org
Marty
