Up Topic Welding Industry / Technical Discussions / Weldable rust inhibitor
- By grayseal (*) Date 10-05-2001 17:31
I am looking for a rust inhibitor to protect carbon steel that does not need to be removed prior to welding. The coating must not harm the weld or the welder. The application is an ASME pressure vessel that will be coated with porcelain enamel after welding.
grayseal
