Up Topic Welders and Inspectors / Welding Equipment Classifieds / WTB Miller Econtig or syncrowave 200
- - By Lance Date 10-12-2006 07:40
Looking for a used Miller unit the econtig will work but will also consider a syncro. Might consider other models too.  Must be AC/DC tig and stick. no more than 200 amp needed.  I'm in the denver area.
lbross7095@aol.com
Parent - - By Lance Date 11-22-2006 01:03
Bump.
I'm still looking.  Anyone?
Parent - - By weldersales (**) Date 11-22-2006 16:48
We have the Econotig at 600.00, Syncrowave 180SD at 925.00, Syncrowave 200 at 1225.00, as well as all the other Miller tigs in stock. These three are all 240 volt units and are without accessories. weldersales
Parent - - By flatwins (*) Date 11-24-2006 03:36
Larry- I talked with you a couple of weeks ago on these. So I'm assuming the Syncro units do not include the Runner cart?  What else would I need?  TIG torch, gas regulator, foot control?  What would these run me?
Thanks,
Steve
Tulsa
Parent - - By weldersales (**) Date 11-24-2006 15:15
Hi Steve,       How goes it? You would probably spend about 250.00 for torch, regulator, hand or foot control, gas hose, ground. Primary cable to wall is already on machine from factory. The runner cart would add about 115.00 to 140.00 to package. weldersales
Parent - By flatwins (*) Date 11-25-2006 14:48
Thanks for the info.  Now to decide between the 180 and the 200.  A few extra amps and a pulser seem to be the biggest difference between the two.  This will just be for home\hobby work and I hope to do a fair amount of aluminum.  If I bought the 180 would I regret not having the pulser?  I welcome anyone's comments\suggestions and I'm going to post this same question on one of the other forum areas as well.
thanks again,
Steve
Tulsa
Parent - By XPERTFAB (**) Date 01-09-2007 17:21
I have a Miller syncrowave 180 for sale including TIG torch and foot amptrol along with stick leads.
Thanks!
Parent - By danielfritton Date 01-08-2007 20:53
I have the miller 180 tig with cart and large owner gas bottle full,new,,look at the for sale section of forum...Thanks..Dan
