Pulse will always have a hum, it's just the audible tone of current and voltage ramping up and down many times per second. The crackle or no crackle just comes from the set-up. Higher wire feed equals more crackle, lower voltage (or arc length in terms of pulse welding) equals more crackle. True spray only comes from using an Ar/02 mixture. While the C02 does get close, it still is a high end, maybe a bit erratic, short circuit transfer, and that ultimately is what the crackle is, every minute short circuit that the wire makes causes a crackle.
