Up Topic Welding Industry / General Welding Discussion / Argon Oxigen mixture/Ar+O2-4%/
- - By panaya (*) Date 01-25-2007 11:49
Hi all
I use Argon Oxigen mixture/96%Ar+4%O2/ for welding mild steel/5mm-10mm thickness/I need your opinions and advices.
Has anybody any experience with this gas?
Parent - - By 357max (***) Date 01-25-2007 16:31
Make a weld on the steel and then cut and etch with 5 cc nitric acid HNO3 & 100 cc ethyl alcohol C2H5OH. Compare with a mixture of 96% Argon 4% CO2. The CO2 mixture will give a more rounded weld bead profile. Check out/measure & compare the total fumes generated between the two mixes. And perform the mechanical tests to determine strengths required. A good test is always better than a thousand opinions.
Parent - By ssbn727 (*****) Date 01-25-2007 17:06
Sounds or rather, "Reads like a plan to me!!!"
Parent - - By panaya (*) Date 01-26-2007 06:33
Thank you 357 max.
Parent - - By DaveBoyer (*****) Date 01-27-2007 04:25
There is a website "Weldreality.com" that might be of interest to You.
Parent - - By ssbn727 (*****) Date 01-27-2007 05:50 Edited 01-27-2007 06:21
Here's the link to what you're looking for:
http://www.weldreality.com/stainlesswelddata.htm
here are some more links within this link:
http://www.weldreality.com/WELD%20PROGRAMS.htm
Here's the Home page:
http://www.weldreality.com/default2.htm
Happy hunting and good luck finding what you need!!!
Parent - By panaya (*) Date 01-29-2007 06:41
Thanks all
