Up Topic Welders and Inspectors / Welding Equipment Classifieds / FS: rotary phase converter 220 single phase in 3 ph out
- - By R.P.C.MAN Date 02-07-2007 19:40
GOLD SERIES
PHASE-A-TRON
$350.00 F.O.B. MICH
ROTARY PHASE CONVERTER
10 H.P./30 H.P.
AN EXCELLENT PHASE CONVERTER
FEATURES:
*220-240 VOLT SINGLE PHASE POWER IN
*220-240 VOLT 3-PHASE POWER OUT
*INSTANT REVERSING OF MACHINE MOTORS
(CHANGING DIRECTION)
*READY TO RUN-OUT OF THE BOX!
*FULLY ASSEMBLED!
(NOT A KIT!
*MADE IN USA!*
*SUPER HEAVY DUTY CAPACITORS
*OVERSIZED WIRING FOR HIGH AMP LOADS
*CONTINUOUS RATED 100% DUTY CYCLE
WILL POWER C.N.C. EQUIPMENT
AS A MANUFACTURER OF PHASE CONVERTERS SINCE 1983 WE ARE NOW BRINGING OUR PRODUCT LINE TO THE INTERNET.
EVERY PHASE-A-TRON GOLD SERIES PHASE CONVERTER NEEDS TO BE SIZED TO A SPECIFIC APPLICATION
IT IS VERY IMPORTANT AS SOME APPLICATIONS SUCH AS AIR COMPRESSORS ARE VERY HARD STARTING AND NEED TO BE OVERSIZED
OTHER UNITS SUCH AS MILLS,GRINDERS,SAWS AND MANY OTHERS
ARE EASY STARTING LOADS AS THIS UNIT CAN START UP TO A 15 H.P. TOTAL LOAD
RUNNING AT THE SAME TIME AS EVERY UNIT RUNNING ACTS LIKE A CONVERTER FOR THE NEXT TO START WHEN INSTALLED CORRECTLY
UPON PURCHASE WE SUPPLY FULL INDUSTRY STANDARD INFORMATION ON BUILDING YOUR TOTAL 3 PHASE SYSTEM
INCLUDING MULTIPLE CONVERTER INSTALLATIONS
IN SOME CASES IT IS BETTER TO ADD ON A CONVERTER AS THE ONE WE LISTED THAN TO BUY A LARGER CONVERTER WHICH REQUIRES HIGHER ENERGY COSTS TO OPERATE.
AS WITH ALL APPLICATIONS ADEQUATE SINGLE PHASE POWER SUPPLY IS A MUST AS WELL AS WIRE SIZE CONFORMING TO NATIONAL AND LOCAL CODES.
THIS UNIT IS FACTORY FRESH!
FACTORY RECONDITIONED
NEW CONTROLS/BOX WIREING CAPACITORS ETC
WE MANUFACTURER A FULL LINE OF GOLD SERIES
PHASE-A-TRONS
FROM 5 H.P. TO 50 H.P. FOR EVERY APPLICATION NO MATTER HOW CRITICAL THAT APPLICATION MAY BE.
WE CUSTOM ENGINEER EVERY APPLICATION, THEREBY PROVIDING YOU, THE CONSUMER A SATISFACTION GUARANTEED POLICY..
THE SHIPPING WEIGHT ON THIS UNIT IS 126 LBS. WE CHARGE ACTUAL SHIPPING COSTS ONLY. PLEASE PROVIDE US WITH YOUR DESTINATION ZIP AND WE CAN QUOTE EXACT SHIPPING COSTS.
MACHINE SAFETY: It is the users responsibility to provide proper safety devices, procedures and equipment to safeguard the machine, or machines, to conform to Federal, State and Local Government Safety Standards and all Industry Safety Standards. INDEMNIFICATION: High Bidder/Buyer Agrees to Indemnify and hold harmless Seller of and from any and all claims or liabilities, warnings, or recommendations available from the original manufacturer, or by failure of the user to comply with Federal, State and Local Laws applicable to such equipment including the Occupational Safety and Health Act of 1970. The high bidder agrees to these terms and conditions!
[IMG]http://i119.photobucket.com/albums/o124/imbztek/rotaryphaseconverter1.jpg[/IMG]
Parent - By DaveBoyer (*****) Date 02-08-2007 04:54
Is this a rotary or static converter? What is the standby [no load] amperage draw? What is the  amperage draw at 10 HP and at 30 HP?
