Hey elliott,
You are going to have to supply more information if you want to solve your problem.
1.) What is the thickness of the metal(frames) you want to weld?
2.) Is the metal painted or bare?
3.) What kind of welder are you using?
4.) What is the wire diameter?
5.) Are you using 100% Argon gas?
6.) What are the heat ranges on your welder?
7.) What is the cfh flow set on the regulator?
8.) Are you working in a windy area?
The metal has to be absolutely bare, degreased and wire brushed with a stainless steel brush. Cleaned with acetone or toluene. Aluminum is quite finicky if not chemically clean. OK.....fill in the blanks....help will be forthcoming I'm sure......Denny
