Up Topic Welding Industry / Technical Discussions / Sandvik SX
- - By Shane Feder (****) Date 03-22-2007 20:15
Hello guys,
Has anyone ever worked with this material ?
Any info or advice would be greatly appreciated.
Thanks and regards,
Shane
Parent - - By jon20013 (*****) Date 03-22-2007 20:20
Shane, I have not worked with that particular material but suggest you e-mail Mr. Frank Babish: frank.babish@sandvik.com
Good luck.
By the way, how's that B31.1 vs. B31.3 issue coming?
Parent - - By js55 (*****) Date 03-22-2007 21:07
Interesting alloy. I would assume that with the high silicon that the typical SS viscosity/edge wetting issues will be somewhat reduced. I wonder how it responds to hot cracking. Keeps us posted as to what Frank says.
Sounds like typical SS technique. Low heat inputs, clean, etc.
Parent - By Shane Feder (****) Date 03-22-2007 21:55
Hello Jon,
I have handballed it to engineering, will try not to lose any more sleep over it.
I have expressed my concerns to the engineers but ultimately it is them that will be signing off on the work.
I think there could be a bit of CYA going on shortly.
Shane
Parent - By CWI555 (*****) Date 03-23-2007 19:32
Assuming one and the same material, it faired well, heat input as I recall was closely monitored. while the demo I witnessed went well, I did take note of the excessive attention that was paid to heat input.
Parent - - By CWI555 (*****) Date 03-23-2007 19:28
(searching through some dust in the brain)
SX piping systems, originating from Edmeston materials engineering, Spec ASTM 312 tolorances ASTM A 530, approval through ASME code case 2029-2. I Believe TUV has had a hand in it somewhere as well.
http://www.edmeston.com/business_areas/sulphuric/index.shtml
I've only seen it once, and that was a demonstration. So I can't claim a whole a lot of knowledge. Initial data looks really good though.
Let me know if this helps.
Gerald
Parent - By Shane Feder (****) Date 03-23-2007 20:20
Thanks Gerald,
Much appreciated,
Shane
