The reason I ask is that I discovered a lamination a couple of days ago while I was cleaning up some spatter on a pad eye, part of a lifting beam. It's not going to see more than 4 tons of weight at any one time.
The lamination is located less than an inch from the hole that accepts the shackle.
The engineer says leave it, but he's prone to shortcutting procedures for time saving. An example would be preheat. At -10 degrees F, I personally don't think preheat is something that should be omitted from welding procedures, no matter the use of the component.
I don't know what the relevant codes say about laminations, but my experience in ths shipyard was they never left a lamination, if they knew of it's existence.
What bothers me the most is that you never really know for sure where and how far the lamination travels, unless you did some UT, or you grind it out.
We had a case a couple of years ago with some heavy wall, 1.5", plain carbon steel steam pipe. It was an extruded material. If you weren't careful while running your hand down the outside of the pipe, you might impale your hand on slivers sticking from the OD. It was decided not to do anything about them. I did have to grind one of them out, as it was located at the weld joint, and appeared as a crack-like indication projecting from the weld into the pipe wall. It was roughly 2" in length, and traveled 3/8" into the pipe on an angle. With the RT requirements, I felt it needed to be removed. I never noticed it until I had completed the first stringer bead on the cap.
I wonder what occurs to the laminations when one applies some cyclic thermal stresses, as you might encounter with start up and shut down.
Dale Simonds
By -
Date 01-19-2002 15:16
In something like a lifting beam, you will need to establish the direction of the stresses. If the lamination is parallel to the direction of stress and it is in tension, then you do not have a major problem.
If the lamination direction is perpendicular to the stress direction (In other words, the lamination is reducing the load carrying cross section.) then it is a problem and needs to be sized and, most probably, removed.
Another issue is when the material with the lamination is in compression when the lamination lies parallel to the stress direction. In this instance, the buckling load of the beam will be reduced.
The above arguments will also apply for cyclic loading.
Hope this helps
Niekie Jooste
