What gap? Did you check for residual magnetism? You will not see fire across the point gap. The Mag has an impulse spring that snaps the rotation to make it fire at the tab on the coil.
With No#1 cyl on TDC compression install the mag set to fire on No# 1 but on the compression side of the impulse.
