Up Topic Welding Industry / General Welding Discussion / Mig Guns or liners For Nickel Alloy wires ?
- - By pipewelder_1999 (****) Date 05-14-2007 18:54
Does anyone know of any "new" products that are available for feeding difficult wires ? I recently talked to a fried that indicated his shop had received some mig guns that would push NiCrMO-xx wire in .045" diameter with no problems coiled in the floor loke a hose. I didn't get the brand name.
Any advice ?
Have a nice day.
Thanks
Gerald
Parent - - By darren (***) Date 05-15-2007 09:31
they are not new but teflon wire liners are what we use when there is a worry of contamination of the wire consumable by the liner and they do feed easier.
darren
Parent - - By MDG Custom Weld (***) Date 05-15-2007 10:23
Darren has it right, we use teflon liners when alloy contamination is a concern.  We also use galvanized liners on some of our high volume robotic welding cells using NiCrMo-3.  It last a lot longer than standard liners, and doesnt seem to drag as much.
Parent - By js55 (*****) Date 05-15-2007 13:22
And as it turns out the Teflon liners also assist in the sliding of the wire through the conduit. Like eggs out of frying pan.
Parent - By pipewelder_1999 (****) Date 05-15-2007 14:33
Do you get pretty good life out of the teflon liners on hand held guns ?
