Hi Brian,
Boilermaker has given you a good tip on the voltage/amp setting to help minimize spatter but I would offer a word of caution. Be cognizant of the voltage/amp balance while attempting to do this! As Niekie stated previously, FCAW (specifically gas shielded) has an arc that “resembles” spray.
If you watch the end of the wire with the proper voltage/amp settings you’ll notice that the arc (not the wire) is quite square and focused toward the puddle. There’ll be a steady hiss with a slight crackle once in a while (slightly globular) and little spatter. It’s been my experience that if the amps are too high in comparison to the voltage by setting or nozzle length, the arc will have developed a soft, “paint brush” appearance (widen out) with all hiss and no crackle. In addition, the weld’s appearance will have a very “savvy” look to it and admitttedly, less spatter.
In many cases though, due to this imbalance (and it doesn’t take much), will allow slag to roll under the puddle’s leading edge. I’ve found this to be one of my most common discontinuities I find when dealing with multi-pass, FCAW weldments and it’s usually traceable back to voltage/amp imbalance and very seldom to operator technique! Interestingly, I’ve observed this phenomenon at all locations around a circumferential weld instead of just at the 12:00 o’clock position of a 5G weld and it’s very, very prominent throughout out 2G’s.
The last example that I was involved in personally in,occurred with a nationally recognized pressure vessel fabricator, field erecting several large diameter 5/8” SS pressure vessels and all of the welds were 2G. Immediately I noticed the scenario I’ve just described and questioned the voltage/amp imbalance after watching with my glass and seeing the “paintbrush arc”. They (the QC inspector & QA mgr.) professed to be within the confines of the WPS and that their welders were using the appropriate technique (granted they were but nozzle length was too close) and no QA was going to tell them anything. They cut out over 250’ of 5/8”SS weld after the required radiography showed unacceptable amounts of slag inclusions between passes! All that just for a savvy appearance and little spatter cleanup!
Please excuse me if I've rambled a little too much on this topic.
