The supplier is correct, Section 14.6 states: "The finished pipe shall be reasonably straight." The intent of this requirement is to encourage the buyer and supplier to set standards before purchase. Having said that, as a buyer you have the ultimate say in what you will accept. Charles Hall
"Reasonable straight" means "straight to the eye". When I was a "just out of school" engineer, I worked for one year in a seamless pipe mill. After each pice of pipe was rolled, calibrated and machined on the ends, and before visual inspection, hydro test and painting, it was straightened in a special machine until it was, as I said, straight to the eye.
A word of caution to Mr. Hall: as a buyer, you've got the ultimate saying PROVIDED you've cleared up in the in the purchase order what degree of straightness you require, as NDT III wisely advices.
Sao Paulo - Brazil
