Up Topic Welding Industry / General Welding Discussion / PICK UP PROBLEMS
- - By TANKIE (*) Date 07-19-2007 23:35
I HAVE SA-200 AND THE PROBLEM IM HAVIN WHEN YOU STRICK AN ARC IT TAKES A LITTLE BIT FOR IT TO PICK UP TO BURN A ROD I BELIVE IT OPERATES OFF OF VACUM? IS THERE A WAY TO SPEED UP THE PROCESS WHEN YOU MAKE CONTACT WITH THE ROD TO WORK?
Parent - - By Mwccwi (***) Date 07-20-2007 16:05
See your other post on this thread. I've hooked you up with a good Lincoln link for stuff like your asking.
Parent - - By TANKIE (*) Date 07-20-2007 22:10
THANKS FOR THE INFO
Parent - - By TANKIE (*) Date 07-20-2007 23:59
thanks info was very help full all it needed was a spring on the idler arm!!! simple fix thanks a bunch
Parent - By Mwccwi (***) Date 07-21-2007 03:13
thank you thats what we visit for to share and learn :)
