Hello BooTLeG, I think I know what you are referring to but a bit more information might help everyone here on the forum to nail it down for you. You refer to hearing popping after you have completed making a weld. Popping, tinkling, other sorts of sounds coming from the stainless could be due to the fact that stainless steel has a high coefficient of thermal expansion(thus it moves and shifts a lot) and after the welding the metal is cooling and shifting at the juncture of the joint, this could possibly cause sound to resonate from this shifting between the two pieces, or from the part moving ever so slightly on the bench or table that you have it setting on and then causing a sound that is amplified through the part. Just a few thoughts to ponder, I'm sure others may have a better explanation, but do consider trying to provide additional information. Regards, aevald
well bootleg i believe that you are not getting enough shielding gas coverage over your welded surface. Couple of questions for you first what is the pressure of your gas flow and also how long in is your post flow setting? I usually use 10-15 psi with a number 4 to 5 size coupler, and with a number 6 coupler 15-20psi. My post flow is set at at least 4-10 seconds long. I have also learned when welding stainless it helps to weld with low amperage and keep the torch over the weld when completed until the post flow shuts off. Then it should be pink in color. if this helps out let me know i am curious about your techniques and am full of suggestions!
