Up Topic Welding Industry / General Welding Discussion / welding dissimilar metals
- - By rtnnhazel (*) Date 09-28-2007 03:12
can i weld s.s. to steel and if i can do i need s.s. or steel filler. can i weld either of those to aluminum or copper( can copper even be welded in a sense of welding and not brazing)? thanks
Parent - - By TANKIE (*) Date 09-28-2007 03:29 Edited 09-28-2007 13:55
YES YOU CAN WELD SS, TO CARBON STEEL, USING AN 309L SS ROD OR SIMILAR WIRE WELDING ALSO DO KNOW WHAT PROCESS YOU ARE USING MIG , STICK, TIG??? HOPE THIS HELPS, TANKIE
Parent - By Tommyjoking (****) Date 09-28-2007 08:01
2nd question.....ummmm no not with aluminum if you could you would be a very wealthy individual....copper can be attached to steel via welding in some limited ways.    You can GTAW copper together using 347 SS filler and a few other fillers.
Parent - - By scrappywelds (***) Date 09-28-2007 22:05
you can most certainly braze s.s and carbon steel to copper with silver solder. you can even solder copper to aluminum, using steel wool, flux, and tin - lead or tin-antimony wires
Parent - By rtnnhazel (*) Date 09-28-2007 23:37
wow you guys really cleared that up for me! thanks for the responses. by the way im using tig
