Up Topic Welders and Inspectors / Welding Equipment Classifieds / sa200 carb
- - By mooseye (**) Date 10-04-2007 02:58
I need a good working order Marvel-Shebler updraft carburator. Linkage on the right looking at the atmosphere side of the bore.
Parent - - By KSellon (****) Date 10-04-2007 18:45
Mooseye-
  I have plenty of the old pot belly Marvels rebuilt. Mike with AEI here in Oklahoma can sell you the zenith replacement for around 140. Are you just needing one for parts? Let me know.
Parent - - By mooseye (**) Date 10-12-2007 14:00
This is on an old SA200. It has a carb on it, but I have had alot of trouble with it. Seems to flood alot. Do you have a rebuild kit for them? I soldered the float once, and it worked fine for a time. It just seems problematic. I have a Zenith but it is wrong handed, off a tractor I think.
Let me know about the kit, please.
Parent - - By KSellon (****) Date 10-12-2007 15:36
rebuild kit # K7505 $21.32. You can get replacement floats and venturi's also. The base jet in those carbs is problematic. We remove everything from the carb, soak it, bead blast it and rebuild it. So far we have been able to guarantee our rebuilds with no problems.
Since you have the R57 on your machine the new Zenith replacement carb is # 13720, AEI here in Oklahoma has them in stock for $190.00. They also carry all the carb kits and magneto parts. 405-236-3551 talk to Mike.
On the engine drive page of our website, down the right hand side, you will find all the details for the Marvel and Zenith carb tear down, etc.
I have rebuilt carbs with metal filters installed in stock for $55.00 + shipping. As long as you have replaced your 5/16 fuel line with new and cleaned your sediment bowl, I guarantee it.
Good Luck
Parent - - By mooseye (**) Date 10-14-2007 01:26
where is your website? I have searched for an hour and no luck.
Parent - By raftergwelding (*****) Date 10-14-2007 04:16
www.billswelderrepair.com
Parent - By raftergwelding (*****) Date 10-13-2007 04:55
you can get the kit from a NAPA parts house thats where i get mine they arent hard to rebuild but she's right you have to clean them good
Parent - By shorthood2006 (****) Date 10-05-2007 02:21
she beat me to it...kay will fix you right up :)
